 [ SCX10 Axial ] by akira "pick up"
akirasurf
akirasurf
[ SCX10 Axial ]  by akira "pick up" Empty
MessageSujet: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 14:27
voici mon scx 10
acheter en version rtr avec la carro "dingo" faux defender en lexan,je me suis attaquer au lien histoire de passer tous ca en alu, un servo d'homme hitec 645mg, moteur 55tours/vario rc4wd 'drag brake/amortos HR120mm en droop
pneu rc4wd jantes landies lest av70grs ar 60grs viré les marche pied pour un model maison en acier
carro de clod buster "chevy" mais avec quelques modif histoire d'avoir le bon empattement
donc decoupe derriere les portes et derriere les ailes ar.
recollage du tout et couvrir la benne en carbone kevlar..
[ SCX10 Axial ]  by akira "pick up" Pict0611u
[ SCX10 Axial ]  by akira "pick up" Pict0617k
[ SCX10 Axial ]  by akira "pick up" Pict0621y
[ SCX10 Axial ]  by akira "pick up" Pict0622v
[ SCX10 Axial ]  by akira "pick up" Pict0603o
[ SCX10 Axial ]  by akira "pick up" Pict0597
[ SCX10 Axial ]  by akira "pick up" Pict0676
[ SCX10 Axial ]  by akira "pick up" Pict0677m
[ SCX10 Axial ]  by akira "pick up" Pict0711t
[ SCX10 Axial ]  by akira "pick up" Pict0713
[ SCX10 Axial ]  by akira "pick up" Pict0716o
[ SCX10 Axial ]  by akira "pick up" Pict0717k
[ SCX10 Axial ]  by akira "pick up" Pict0718j
[ SCX10 Axial ]  by akira "pick up" Pict0719
[ SCX10 Axial ]  by akira "pick up" Pict0721i
[ SCX10 Axial ]  by akira "pick up" Photo154a
[ SCX10 Axial ]  by akira "pick up" Photo234w
[ SCX10 Axial ]  by akira "pick up" Photo001dt
[ SCX10 Axial ]  by akira "pick up" Photo002yi
[ SCX10 Axial ]  by akira "pick up" Photo005dy
[ SCX10 Axial ]  by akira "pick up" Photo004r
[ SCX10 Axial ]  by akira "pick up" Photo003z
[ SCX10 Axial ]  by akira "pick up" Photo012eb
[ SCX10 Axial ]  by akira "pick up" Photo015f
[ SCX10 Axial ]  by akira "pick up" Dscf3235n
j'ai pas encore fais de photo en version fini....ca va venir
l'accus est passé devant le moteur ,l'electro derriere,et les marches pieds on disparus au profits de tube de renfort
a bientot
seb.
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 14:51
voila donc le roman photos de ce pick up bien qu'il ne soit pas fini...
la carro de chevy a recus des contours d'aile de F350 (made in bartwasa),
j'ai rallongé donc de 1cm derriere les portes,racourcis de 1cm aussi le hayon vers les ailes arrieres afin de limiter le porte a faux et de tomber bien au niveau du pare choc d'orgine du scx10.
les pneus des photos etais les tomahawk rc4WD montes sur jantes tam,mais le deport ne me convener pas donc retour au jantes landies avec les rock creeper rc4WD, bon compromis.
les marches pieds etant un peu bas ,ceux que j'ai refais sont proche de la carro afin d'augmenter les capacité de franchissement,car souvent on pose le marche pied en plastoc..
les dernieres finitions sont faites,et je suis super satisfait des capacités de l'engin.
j'utiliserais sans doute le meme chassi pour un projet futur.
[ SCX10 Axial ]  by akira "pick up" Photo_12
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 14:57
la benne en carbone kevlar, il fallait oser clin
la bière.... la je suis déçu :lol!:
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 16:09
ben finalement c'est pas si mal....non?
et je ne transporte pas que des bieres......
[ SCX10 Axial ]  by akira "pick up" Photo685
[img][ SCX10 Axial ]  by akira "pick up" Photo720[/img]
maintenant en droop ca croise severe,bien plus que du reel..
a+
seb.
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 18:22
a+
seb.
oui, il plus que pas mal clin
pour les croisements de ponts, c'est vrai que ça croise plus qu'un vrai, mais bon, ça choque pas plus que ça clin
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 18:39
Il est cool.
Pour les croisements je préfère quand c'est limité sur un scale.
Je trouve plus réaliste des passages sur trois roues qu'un croisement de crawler.
Cela n'enlève rien a la qualité de ton boulot sur la carro. :cheers:
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 18:52
Il est cool.
ouais, mais ça va, c'est pas excessif clin
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 18:56
Oui .
Temps que le haut de la roue ne descend pas plus que le bas de caisse, ça reste acceptables Very Happy
VINCEREEF
VINCEREEF
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 19:00
Et encore un scale au top !!!! et c'est vrai que pour un scale le croisement doit rester résonnable, pour ne pas me contredire [ SCX10 Axial ]  by akira "pick up" Lol mon paj' croise fort mais c'est dans son esprit compét',
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMer 30 Juin - 19:17
effectivement celas doit rester limiter dans la limite du raisonnable bmuhuha
celui ci est plus typé facon ricain donc tout exagerés,la c'est sur que avec des 120mm c'est un peu plus que raisonnable mais le montage en droop et souvent la cause de cet effet,ceci dit le montage en droop a un avantage c'est que quand tu roule a plat sur un chemin....ben il sautille comme un vrai,il est bien raide sur ses pattes,donc un peu comme les vrais,c'est que lors de certains croisement que c'est accentués mais dans l'ensemble c'est correct,et je passe souvent sur 3 roues malgres ca ,mais les capacités sont bluffantes.
a tres vite
seb.
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMar 10 Aoû - 18:38
magnifique :affraid: I love you je pense que c'est un effet visuel mais on dirait que la cabine et trop petite par rapport au reste du vehicule :suspect:
j'adore l'eclairage avant tu a pris ca ou 😕 et je vois que tu a beaucoup de roues p tu en a pas 4 pour moi pas cher en 1.9 ou 1.5 p p
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeJeu 12 Aoû - 15:45
ben l'eclairage c'est celui d'origine du scx 10,la cabine est pas mal proportionner pourtant ,c'est celle de la carro de clod buster..
et pour les roues ben desolé mais je n'en vend pas,c'est pour mes futurs projets..
a+
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeJeu 12 Aoû - 15:52
je la trouve plutôt bien moi cette carro clin
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeJeu 12 Aoû - 20:46
oui moi aussi je trouve cette version avec passages de roues tout en rondeurs, bien sympa
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeVen 13 Aoû - 8:46
je la trouve tres belle aussi pas de probleme de ce coter la mais je disais juste que sur certaines photos il y avait comme un effet visuel
( c'est peut etre mes yeux [ SCX10 Axial ]  by akira "pick up" Icon_cyclops [ SCX10 Axial ]  by akira "pick up" Lol )
que la cabine n'est pas proportionner mais ca ne doit pas etre le cas [ SCX10 Axial ]  by akira "pick up" Icon_exclaim
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeMar 31 Aoû - 2:13
Ben t'as tord ! bmuhuha
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeDim 26 Sep - 15:53
eh hop je degage le pare choc av et ar pour faire du sur mesure en ferraille...
je me lance dans mes premieres soudures....
allez zou a l'atelier...
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeDim 26 Sep - 18:38
[ SCX10 Axial ]  by akira "pick up" Icon_cheers impatient de voir ca [ SCX10 Axial ]  by akira "pick up" Icon_twisted
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeDim 26 Sep - 20:02
@akirasurf a écrit:
alors?? ça a donné quoi ses soudures? Very Happy
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeDim 26 Sep - 20:55
ben je sors de l'atelier et j'ai fini le pare choc avant..pas facile d'etre bien droit au debut donc on reprend tout ,mais on s'accroche,ca fini par marcher...
les lampes a souder chauffe tout juste bien...je vite investir dans un vrai poste moi [ SCX10 Axial ]  by akira "pick up" Icon_scratch
j'ai fini l'avant et j'ai remis en lieu et place les lumieres d'origines en montage a blanc et ca le fais ..une couche de peinture antirouille noir en sous couche et une couche de noir matt pour finir..
mais bon ca le fais et je suis pas mecontent [ SCX10 Axial ]  by akira "pick up" Drunken_smilie
allez je mange et je vais finir tou ca et demonter l'arriere pour commencer ca => allez zou
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeDim 26 Sep - 22:12
@akirasurf a écrit:
tu pourrai au moins nous faire une photo Very Happy
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeLun 27 Sep - 8:23
+ 100000 [ SCX10 Axial ]  by akira "pick up" Icon_twisted
akirasurf
akirasurf
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeLun 27 Sep - 9:24
ouep mais bon la nuit a passer et il ne me plait plus.....
donc j'y retourne...
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeLun 27 Sep - 9:29
[ SCX10 Axial ]  by akira "pick up" Icon_sad bon courage
MessageSujet: Re: [ SCX10 Axial ] by akira "pick up"   [ SCX10 Axial ]  by akira "pick up" I_icon_minitimeLun 27 Sep - 11:36
même tout pourrit c'est pas grave bmuhuha
