 [nouveauté] CROSS RC PG4S + upgrade
[nouveauté] CROSS RC PG4S + upgrade Empty
MessageSujet: [nouveauté] CROSS RC PG4S + upgrade   [nouveauté] CROSS RC PG4S + upgrade I_icon_minitimeMer 16 Sep - 7:29
[nouveauté] CROSS RC PG4S + upgrade Logo
SOURCE ICI clin
Video Link:
http://v.youku.com/v_show/id_XMTMyNzcxMDIwOA==.html
1:10, 4x4, PG4S & PG4RS
[nouveauté] CROSS RC PG4S + upgrade 20150909143003
[nouveauté] CROSS RC PG4S + upgrade 20150909143022
[nouveauté] CROSS RC PG4S + upgrade 20150909143029
[nouveauté] CROSS RC PG4S + upgrade 20150909143036
[nouveauté] CROSS RC PG4S + upgrade 20150909143043
[nouveauté] CROSS RC PG4S + upgrade 20150909143104
PG4S is configuration of the latest CROSSRC matching high torque 27T motor dual speed gearbox, transmission using metal casting shell, with precision gears and gear shift mechanism. The first gear ratio is 1:7.69 and the second reduction ratio of 1:3.34.
[nouveauté] CROSS RC PG4S + upgrade 20150909143156
[nouveauté] CROSS RC PG4S + upgrade 20150909143204
[nouveauté] CROSS RC PG4S + upgrade 20150909143210
[nouveauté] CROSS RC PG4S + upgrade 20150909143232
PG4S follows the PG4 overloaded the whole axle, the suspension system was designed and Re adjustment according to the characteristics and requirements of the extreme cross-country climbing movement. The new design front & rear spring hydraulic shock absorber, the shock tube diameter up to 15mm.
[nouveauté] CROSS RC PG4S + upgrade 20150909143316
PG4S is used latest CROSS RC 2.2inch “FAT-MAN” cross country tyre, the diameter of tyre is 135mm, tread width is 56mm, configuration with 2.2inch metal hub.
[nouveauté] CROSS RC PG4S + upgrade 20150909143359
[nouveauté] CROSS RC PG4S + upgrade 20150909143428
[nouveauté] CROSS RC PG4S + upgrade 20150909143654
[nouveauté] CROSS RC PG4S + upgrade 20150909143703
[nouveauté] CROSS RC PG4S + upgrade 20150909143737
[nouveauté] CROSS RC PG4S + upgrade 20150909143751
[nouveauté] CROSS RC PG4S + upgrade 20150909143802
[nouveauté] CROSS RC PG4S + upgrade 20150909143817
[nouveauté] CROSS RC PG4S + upgrade 20150909143855
[nouveauté] CROSS RC PG4S + upgrade 20150909143905
[nouveauté] CROSS RC PG4S + upgrade 20150909143914
[nouveauté] CROSS RC PG4S + upgrade 20150909143926
[nouveauté] CROSS RC PG4S + upgrade 20150909143934
[nouveauté] CROSS RC PG4S + upgrade 20150909144005
[nouveauté] CROSS RC PG4S + upgrade 20150909144018
[nouveauté] CROSS RC PG4S + upgrade 20150909144027
[nouveauté] CROSS RC PG4S + upgrade 20150909144037
[nouveauté] CROSS RC PG4S + upgrade 20150909144047
[nouveauté] CROSS RC PG4S + upgrade 20150909144100
[nouveauté] CROSS RC PG4S + upgrade 20150909144112
[nouveauté] CROSS RC PG4S + upgrade 20150909144122
[nouveauté] CROSS RC PG4S + upgrade 20150909144129
[nouveauté] CROSS RC PG4S + upgrade 20150909144143
[nouveauté] CROSS RC PG4S + upgrade Smiley-transport020 [nouveauté] CROSS RC PG4S + upgrade Emoticon-transport-002 [nouveauté] CROSS RC PG4S + upgrade Image [nouveauté] CROSS RC PG4S + upgrade Bumpy
MessageSujet: Re: [nouveauté] CROSS RC PG4S + upgrade   [nouveauté] CROSS RC PG4S + upgrade I_icon_minitimeMer 16 Sep - 21:15
Hummm vais voir zieuter tout ca
Les élargisseur le par choc avant
Des ponts Alu?
[nouveauté] CROSS RC PG4S + upgrade 4x4-ex10
aristote
aristote
MessageSujet: Re: [nouveauté] CROSS RC PG4S + upgrade   [nouveauté] CROSS RC PG4S + upgrade I_icon_minitimeJeu 17 Sep - 6:34
Je l'avais repéré sur le dite constructeur et c'est une nouveauté intéressante!
Merci pour la news
» [nouveauté] CROSS RC PG4S + upgrade
» [Upgrade code error]HTC HD bloqué écran tri-couleurs
» Photokina 2008 : Les nouveautés, les rumeurs
» nouveautés 1er semestre 2009
» Nouveauté Trumpeter
